Controlling Elements
How can I control individual elements of a webpage (text block, etc.) so that they are visible only on desktop, mobile, or other devices?
In the inspector settings → Layout → Display you can toggle ‘‘hidden’’ for each element / breakpoint.
Greetings,
Mike
Hi Mike,
Thanks for the tip. Unfortunately, it doesn’t work properly for me (Elements V 3.1.3).
When I hide an element in the “Mobile Portrait” layout, it gets hidden in all layouts. As soon as I select a different layout from the bar at the top and make the element visible again, it also becomes visible in Mobile Portrait. So I can only save one setting at a time—I can’t have different settings for different display layouts.
If I copy a container from an Elements template—for example, one where the GRID setting is configured to display only one column in mobile view but two columns in laptop view—then it works.
Is this a bug in my version of Elements or in macOS 27.2, or am I doing something wrong?
Greetings, Stefan
Sounds like you might be using it wrong
Watch the Breakpoints video in the Element Docs to learn how to use this feature.
If you’re still stuck after watching the video let me know and we can take a look at your project and what you’re trying to achieve!
Hi Dan,
Thanks for your tips. That’s exactly what I did, but it didn’t work.
I just created a new project without using any template—and lo and behold: it works.
I had previously built my website using the “North Eleven” template, and that feature doesn’t work there.
Thanks!
Best regards, Stefan
