'Copy and Paste Properties' !?
Each element has a ton of settings - I’m often thumbing through all the settings to find the one that affects a particular property I wish to emulate (eg: border width) … even though I’ve done it many times before
Example - When setting up multiple containers … it would save a ton of time to be able to “copy and paste properties”
That’s my wish of the week
You can select more than on by holding the command key and the settings you then choose will be applied to all selected.
Hi Jan … I realise that - thank you. It’s not really what I’m asking for.
My suggestion is more like copy an associated properties in Photoshop where all appropriate assets from one layer may be applied to another
Jol
