Create templates
Hello how can I create templates and then save. E.g. banner or footer.
I want to close Elements and be able to access my pre-built banners and other elements when I restart a new project.
Viele Grüße
Mike
We are working on the Templates feature and it should be available soon-ish. This will allow you to build Templates and re-use them in other projects.
For now, you can copy and paste between documents. Hope that helps!
As templates not ready yet I save mine as globals in a project called templates, design them all there and copy them across in to my project. I found the example projects great to learn from.
