@dan where does the css file get places, what name should the css file be called
Take a look at the Snowstorm page asset example on Github, it has a js file in the Assets folder, but you can store anything in there, including CSS files.
You’ll need to remember to add the code to the hooks file, check the docs for more info.
Let me know if you get stuck!
@dan I have some css in the Styles section where should this go. I have copied the html and properties but not sure where to put the css in Styles
if I look at the page in safari it gets added to the index.css, not sure how this works in devpac component
it works now n ow need to add it was just picking up the divider no need to add styles css
