CSS Coding Help
I looking for CSS Code help in re-sizing the Privacy Notice (attached photo)- Width and Centering if possible…
I’s like to use this as an "informational advertisement sort of.
Also, is there a way to limit the the length of time for the “Badge Display” feature ?
How can I use the badge display on some pages and not others?
Can you change colors of the badge display?
Thanx in advance,
Pearson
Can you post a link to the live site so we can take a look at the source?
Dan, I disabled the Privacy Notice, because it didn’t look good.
I have copied the source page from Pre-View window. This is what I believe you’re looking for:
Now Stocking 4'-6'-8'-10' Open Trench Drains
Ready to Ship – Complete Drain System – Ready to Install:
✓ V Body = 12GA T304 2B SS
✓ Covers ( Bar Grating or Optional Solid Plate)
✓ Perforated Basket
✓ Leveling Brackets
✓ Special Duty Rated - 12,500 lbs.
Detailed information can be found here
Dismiss
Let me know if this helps.
Thanx,
Pearson
Do you have a link to the site online? To be able to try and supply some CSS code to fix your issue I need to be able to view source of the entire page (i.e. see it online).
