CSS failure with CMS in Elements 2.1.1
I’ve had issues with the newest release of Elements - v2.1.1. The CMS was working perfectly until I made some changes to colours and re-published. From that point on the posts failed to render properly and the error log showed that it was trying to find the CSS in the wrong directory with a peculiar path:
[08-Mar-2026 00:03:45 Europe/London] CMS Item not found: ../cms/posts post.css
The directory cms/posts is where the Markdown text lives. The css for the Post page itself is found at post/post.css.
Is this an Elements bug or is there something that has gone wrong within my project? When I preview the Post page within Elements it renders correctly. It just fails to link the CSS when published.
The Elements Cloud version is at: elementsapp://downloadDocument/eulM0mt796i6
An example of the result is at Post
@dan Any thoughts on this one Dan? Am I doing something wrong?
Hi @curlypaws
I’ve jut had a look at your site, and I think the issue could be that you’re setting the individual post page’s filename to be post.php instead of index.php — is there any specific reason why you’ve done that?
Could you try setting the Post page’s filename to index.php, republishing all files, and then testing if the page works as expected?
It looks like a user who has switched from TCMS to the Elements CMS.
Setting the blog post entries to filename to be post.php is a common approach to achieve a cleaner and more meaningful URL structure.
For example:
/blog/?item=my-blog-post
Whereas in Elements it usually looks like this:
/blog/post/?item=my-blog-post
But I might also simply be mistaken.
Thanks very much @ben and @Pegasus , changing the page name back to index.php did the trick.
I had started trying to change the names to more meaningful ones but didn’t realise that would cause issues for the CMS.
