Curvy header
Is there any way to create a curvy/wavy header or divider?
Like in the past with Mask in RWC.
(without using an svg or image)
Greetings,
Mike
Do you have an example screenshot or link to a site with the look you’re after? :slight_smile:
Hiii Ben!
Here is a screenshot and the website link. You have to scroll down a bit.
Thanks!
www.yools.be
Any particular reason why you don’t want to use an SVG for this?
I could create a demo project for you using an SVG, if you’re ok with SVGs :smiley:
Hiii @ben !
Just because i am not good at drawing haha.
If you can make an example project with an svg, thats okej :stuck_out_tongue:
Thank you!
Is there a way to get easy curvy / wavy svgs?
Thanks Ben!
Lot of tools out there on the internet. Here’s one.
@MikeV,
Don’t forget, that if you download an svg, just change the fill # colour to “currentColor” so you can pick a tailwind colour in Elements. Like this:
Just tested this and you might get an antialiasing rendering issue… as seen in this video:
The easy way to fix this is to use the Transform property and offset the svg down 1pixel so the svg and the container overlap. This will eliminate the sub 1 pixel line on resize.
:backhand_index_pointing_right: Open the Project file in Elements.
God, I never knew about this site :open_mouth:
Thank you!
Thanks Dan for the example project and the explanation!
You guys rock! <3
looks like @dan beat me to it!
Let us know if you have any other questions or need more help :slight_smile:
Thank you!
