Custom Component Property - Check Box
Q1: What is the format for a Custom Component Property for a check box?
Q2: Is there a list of Propert Types?
Hi @logrunner,
We have a switch, it’s the same as a checkbox.
We’re still working on the developer docs, they are being added to every week. Here’s a link to all the UI Controls section.
Here’s a code snippet to paste into your properties file. You can reference the value in the Template file by using the property name {{display}}.
  "groups": [
      "title": "Item",
      "properties": [
          "title": "Lights",
          "property": "display",
          "switch": {
            "trueValue": "on",
            "falseValue": "off",
            "default": true
