Custom components test for me
ok, additional take on this custom component, it is not responsive just me testing and learning. I included overflow hidden/visible
I created 4 quadrants in Elements then dropped the custom component in each one, all shapes are editable (within the controls assigned)
With overflow on all shapes , they can move -1000px and 1000px left right up down outside of their own quadrant, z-index for each component, hide or show
The only bit that does work is show in browser resource images do not show (bug)
Not sure where Elements is planned to go, but if I can do this then wow again, great work from Realmac
I might get time to play with Elements normal if you hadn’t provided this additive custom Elements
https://www.dropbox.com/scl/fo/7jnso2v1elq4snfz1pri5/ANxBNaVYXTRaLMXoANKWGVo?rlkey=ylkyftgjijkvr0farynbcgvyk&st=ddska91s&dl=0
If I understood clip paths I might progress - working on this
Works great and is absolutely crazy :crazy_face: Nice job! The possibilities with custom components are endless :star_struck:
