Custom Componet PROBLEM
Sorry been away for a while, just started a custom component and I have to keep rebooting to get the different parts to work as it does not allow me to do anything. I have a project which has three parts and I can edit one but not other two, Reboot and I can edit second but nothing else and just rinse and repeat, I can NOT share project here as its not ready for public consumption, I just want to know if editor is “sick”? APOLOGIES if this has been asked before! @dan
Are you describing this error: HTML Component Bug in V1.5.5 ?
I don’t know as been away for a month. Is there a known bug? TIA
Yes there is a bug
Thanks and I’m sure you’re as happy as me as we wise this a lot! Take care
This is on the list to fix, very soon!
The current workaround is to show the sidebar in the component editor, this bug only affects macOS Tahoe.
Do you mean the menu that has Templates, properties etc? If so I have been working with them open and it doesn’t make any difference. THANKS for getting fixed ASAP.
