HI guys, introducing **Custom Curso**r for Elements.
This is something special, and I had a lot of fun building it. It’s not just a tool for personalizing feedback, it’s a very flexible narrative tool.
Some demos include animated GIFs from Giphy, a never-ending library to draw from.
Custom Cursor adds fully customizable cursor effects and interactive content positioning to any project. Designed for smooth, modern, and lightweight desktop interactions, it turns a normally anonymous element into something communicative and expressive
Content area — Drag text, images, video, audio
Cursor — Drag images, text and/or svg
How it works
Replaces or extends the native cursor with full control over visibility, motion, fading, and positioning. The Family system gives a group a shared cursor identity while each element keeps its own variation.
What you can do with it
On images it enhances gallery consistency or adds expressive interactions. On video it transforms the play button and displays contextual info directly on the preview. In a shop it guides attention and highlights product details. On text it adds an informational layer or replaces the cursor entirely.
Motion and behavior
Cursor Follow makes the cursor glide with natural inertia. In nested groups, different speeds communicate hierarchy. Cursor Tilt adds a directional lean in 2D, Y-axis 3D, or full XY mode, with adjustable resistance.
…If you are a creative person and love to experiment this is the right component! Using follow (delay) and Tilt together you can create suggestive effects that can be associated with many different subjects.
Furthermore, working in group multiplies your expressive capabilities, allowing you to show the important parts of the site’s content instantly.
The demo illustrates each type of application,listen to the introductions and it will be easy to understand what it can do.
Custom Cursor is available in the Marketplace!
Now in promo ![]()
thanks!
