★ Custom Scroll ★ Speed, inertia, and navigation response
Hi guys, introduci ’ Custom Scroll’ a component ‘under the hood’ :astonished_face:
this component affects the Elements code and does not add anything visible to the layout but improves the behavior of other functions
Customize speed, inertia, and navigation response for trackpads, mouse wheels, keyboard controls, and anchor links.
custom_scroll_multithemes_002
Custom Scroll lets you adjust the native browser scrolling behavior in a simple and controlled way. It makes navigation feel smoother and more consistent across your site by tuning speed, inertia, and input response. It works seamlessly with mouse wheel, trackpads, keyboard arrows, and anchor links, improving the overall scrolling experience in an automatic and responsive way.
Beyond functionality, it also adds a subtle touch of personality and elegance to the way users experience your content. It’s designed to fit both small and large websites, giving you full control without complex setup. If you have long target scrolls in your project this is the perfect component, also useful if you have very long pages. :ok_hand:
The online demo shows 4 different settings.
custom_scroll_multithemes_003
Get complete 3-in-1 navigation control for both large and small sites, and for short or long pages. Adjust scroll speed and arrow step behavior to balance control across every project.
Each setting is fully independent and can be enabled or disabled separately!
Custom Scroll is available in the Marketplace!
Now in promo :grinning_face:
thanks!
Hi @MultiThemes
Congratulations on this truly outstanding component! I purchased it just right now and tested it alongside my scroll animation components in the store, and it adds a genuinely elegant.The scroll feels smooth and delightful in a really impressive way.
Well done, great work — you can really feel the care and attention to detail that went into it! :clap:
Grazie Christian! :folded_hands:
Thank you so much for the kind words, really appreciated!
Glad it works well with your scroll setup and feels smooth and elegant. I tend to be quite meticulous, so it’s great to see that attention to detail come through.
Thanks again for the feedback!
btw, More components are on the way soon.
Custom Scroll is AI-ready :light_bulb:
This update makes Custom Scroll fully compatible with the Elements AI Assistant. Every option now carries a clear, plain-language description.
Just describe the feel you want. Ask for “a slower, softer scroll with smooth jumps to page sections” and the AI sets speed, inertia and anchor timing for you. It also knows the limits, such as leaving keyboard control off on pages with forms.
So, If you haven’t purchased Custom Scroll yet, now is the time to take a look at the demos, if you already have, make sure to update it.
thanks!
