Customising URLs Without Changing Page Titles
Can you customise the page URL without changing the page title? The URL is automatically generated from the page title, but the field is greyed out and only offers a “copy link” option, so it doesn’t seem like there’s a way to manually override it.
Hi @jackesquire
The field shouldn’t be greyed out. These are the two fields you’d change to modify the URL, however the filename should be index.html or index.php in most cases. The folder is where the modification should be focused.
If you are seeing something different let me know.
Cheers
I have a question. Is it wrong to put a / Folder input like this /foldername/ in the url. is it better just to use only foldername.
Only the folder name, Elements will fill in the necessary / in the URL.
