You know your software is in a good spot when this is the kind of feedback you get
. In light mode, the Global Component icons are green, which makes them easy to distinguish — great touch. However, in dark mode, they’re the same color as the Custom Component icons, which makes it hard to tell the two apart at a glance. Could we keep the Global icons green in dark mode as well?
Good suggestion, I’ve added a note to get this improved ![]()
