Delete Project from Rapidweaver
How do I delete a project. Not just clear it from the window but delete it ffom my computer
@sunbeam Hi Cathie, i would suggest you click on the project name at the top and in the centre of the RW Window, this will show you the Folder in which your project is currently saved, you should then be able to locate the project file in Finder.
Tim
Tim, fantastic advice. It worked instantly. Your brilliant.
