Deleting old unsupported plugins
I continue to get the couldn’t obtain principal class for three old/unsuported plugins Lockdown, Pluskit, and Sitemap that I no longer use and want to delete, remove, uninstall ---- for the life of me I cannot find them, there files, or any reference to them other than on the RWC startup page when the error presents itself. . . Thanks.
NOTE: While I know that running under Rosetta removed the error - what I want to do is to delete the plugins since I not want or need them and the developer does not appear to support them under Mac Silicon. . .
You can find (delete or disable) them via the Addons Setting window…
Hope that helps!
