Demo project files missing
Hi Elements Users,
I can’t find the demo project files in the Store. Where can I find them? A demo file is necessary to understand some of the components.
If you reference a component demo project, when you open the Create a New Project window in Elements, you will find the demo project in your library.
Thanks for the tip, Massimo. Now I can take a closer look at how some of the components are used. Up until now, I’ve always used “New Empty Project” because I didn’t want to use a template.
