Is there a way to disable robot tags for an entire project rather than going through page by page?
I need to publish a test version of a live site to play around with and I don’t want search engines finding the test version
The safest way would be to put it behind a password.
The other way is to add a robots.txt file to the root level of the URL.
User-agent: *
Disallow: /
You can also find more information about robots.txt including a test tool here:
Thank you @teefers - no way to do so within RW however?
Not built-in. There’s a plugin
https://4gnd.com/store/index.php?product/page/39/RapidBot+2
I’ve never used it so can’t say how well it works(same developer as RapidCart pro).
Robots.txt is a simple text file, pretty easy.
