Disappearing cursor in Text or Typography cursor
The text cursor/caret/insertion point disappears:
  1. at the beginning of a line with text
  2. on a line where there is no text at all
Could this be fixed? If you double-click one of these components and click a blank line or the beginning of a line with a mouse, you have no idea whether you have succeeded in entering edit mode.
See the video.
Also related to allowing users to edit Text/Typography components without a mouse or trackpad, such as using the Enter key or Control + Enter ( Text component - keyboard shortcut to edit text ). This is an accessibility issue, too. There is no way to use the keyboard within Elements to go into edit mode. This is not, perhaps, an issue if you have limited amounts of text and do not need to edit, but if you have to edit a lot of text or components or have to regularly change text, it is irritating to remember you have to always double-click with a mouse or trackpad before you can do so. Also, if you have hand problems (writer’s dystonia, etc), it can be painful/difficult too.
