Display and resolution
Hello and Moin,
I have an LG Monitor 21 inch here and unfortunately the template looks different than desired.
So what do I have to do to make it look the same as the start sequence in the video?
If I now push the window back to the one monitor then the pictures are among themselves. So which adjusting screws need to be changed.
As I said, the monitor is 21 inches with a Full HD resolution.
It’s similar with my Iphone 16 Pro Max … I have too much air on the right and the writing overlaps at the bottom
What exactly do I have to change where.
Beste Grüße
Mike
Hey Mike,
your video example is made with “ShortCodes” Beta? If yes, the problem should be fixed with the Beta I have running here on my side.
Regarding the second part, there is one container on your side which is wider than the others. I suggest to first identify the container causing the issue. I would delete one and check if the design is ok. If not, then delete the next one. Continue until the design fits and then check the container (and subcontainers) what’s wrong.
Ok I think I found it.
On the pictures, two are correctly wide and two are not - when comparing it is noticeable that three additional entries are displayed at the bottom, exactly where the text is. I guess I have to make the container wider – or am I thinking wrong? :blush:
ShortCodes does not make the error.
Hey Mike,
when I remember well, there was a bug in the Nextlook Project File. Please download the latest version, open the example file and replace your “Dieser Artikel…” with the one from the example file. That should solve it.
Good morning Markus,
That was the right tip :slight_smile:
Now it also works in the iPhone etc. How could I miss that. Also that with the update I thought I had already worked with the latest version.
But … Thank you
