Displaying PDF in Modal or sizing with Lightbox
Ah you wuss thats not cold and obviously not much more snow either. Grit your teeth and go and make me a snowman! :rofl::rofl::rofl:. It’s just wet and grey here!
Hopefully thats what you want but if need any further help just ask.
Take care stay warm and keep on elementerring!
Well, darn. All looks great in the preview. Resume and Report displays perfectly. However, once published the pdf doesn’t display. What am I missing?
check out: https://test.bailin.works/ (scroll to resume and click.
Check out: Mexican Bowl Treatment (scroll to Report and click on top image.
I should add that the pdf downloads even with this display error.
Can you post links to project and I’ll have a look or if you don’t want them in public domain yet, put them in cloud and email me the link at paul@mooreuk.co.uk TIA
it will be tomorrow as just off to swimming again with grandson.
David working on this but before I do can you change something and see if it works.
I was informed by Greg at Chillidog to change my SERVER setting to nacho.chillidoghosting.com:23261 if I was using SFTP yours is ftp.bailinstudio.com:23261
I dont know whether this affects the problem or not but want to check before delving into fixing problem.
Also my problem was fixed by the Other Dan coming on line and checking everything and in the end after a lot of pain and searching the problem was simple - all my domains were on php 8.4 and a lot of things in Elements need php 8.2+ to work. My subdomains which I use as my test domains never updated from php 7.1 and hence my problem. Once they were updated everything worked. So check you php for the test sites too.
If you can confirm you have checked and tried this and its still a problem also let me know as the Other Dan is also looking at this for me too.
Take care!
Paul
