I’m still on RW 8 and Stacks 4. If I upgrade to RW Classic 10, will Stacks 4 work or do I have to upgrade Stacks also (to Stacks 5)?
Yes, Stacks 4 works with Classic 10, you might need to update to Stacks 5 depending on your macOS. But in short, yes, you’ll be fine to update to Classic 10 (Beta)
Ah, that’s brilliant. Thanks!
Do you perhaps know what the highest macOS-version is that Stacks 4 still works on?
