Duplicate Blog and Cache not refreshed
I published a blog today From C++, Swift, and Python to Rust & CQRS: The Multi-Language Evolution of LogViewer
The problem statement: There was an URL in there which I forgot to update before I published i.e. https://cycleruncode.club/blogs/blog/cqrs-pattern-macappupdater/
I realised this and updated the URL and republished - Scaling to 1.5 Billion Lookups: Why We Chose CQRS over NoSQL
Now this happed to be about two hours difference; so I was expecting the post to be updated now.
Issue:
  1. The blog did not get updated, the URL still stayed the same old.
    • Tested in 3 different browsers
    • Tested incognito mode
  2. Logged into to server and found
    • The same md file with yesterday’s date (was in draft state) and today’s date
    • Removed yesterday’s dated file
    • Tried to re-publish via Elements, still no success
    • Edited the md file directly on the server and all seem fine
Help:
  1. What did I do wrong
  2. Why did the site not get updated when locally everything seems to work and links have been updated?
  3. If I publish a new blog / site update later in the next couple of days; should I expect the issue to be resolved? If this continues to happens, what are my options?
Not sure I understand the sequence/actor(s) is here. You may be talking about the synchronization issue several of us have been discussing, or it might be something else. You also mention “draft” as opposed to “published.” I think we either need more details or need to see the Elements file you’re working with.
Thanks @thominator for the response.
This may already have been discussed, so please forgive my ignorance. Let me clarify the issue:
  1. I wrote a blog post and saved it as a draft, but it had the wrong URL.
  2. I completed and published the post without updating its status or URL.
  3. A few hours later, I realised my mistake. I updated the status and URL, then republished it.
The updated status and URL appear to have been published successfully. I can see the new post, but the URL displayed in the post is still the old one and has not updated.
This is when I performed step 2 from my original post: “Logged into the server and found…”
Hi @vivek
Did you try a “Republish All Files”? If not, try that if you run into the same issue again :slightly_smiling_face:
Thanks @ben, shall try that next time
