Duplicate Open Graph meta tags when using CMS Item OpenGraph settings
For my blog posts, I’m using the Open Graph option from the CMS item.
When I select “Article” as the type, it is applied correctly.
However, I noticed that further up in the source code, Open Graph meta properties are already being output. In the og:type property there, the content is marked as website.
Where or how can I configure this so that duplicate Open Graph properties are not output, or so that they are properly overridden?
Elements and the CMS are two separate systems…
The only way I can think to fix this right now is to remove {{page.opengraph}} from the Site Template, however, that would mean you’d need to add opengraph tags manually to your other pages :face_with_spiral_eyes:
Not sure of the best route to go with this :thinking:
