Duplicate without content
If I want to duplicate a “content/text” block, for example, but it’s empty, can I use “Duplicate Without Content”?
Is that the correct way to do it?
I’m not sure because when I use this command, it has the same effect as “Duplicate”! It copies the block but with its contents.
That’s not a bug, is it?!
When you “Duplicate without Content” it should only take the top level component, like this…
CleanShot 2026-03-19 at 11 .26.50
Check again in the next build of Elements (due soon).
If I understand correctly,
I cannot use this command for a block/text below in your example?
If you duplicate a text Component it will include the actual text content. The “Duplicate without Content” is meant for components, perhaps we need to update the name to avoid confusion :thinking:
Or maybe have it only available on components? Alternatively, possibly dynamically change output based on selection: i.e. current functionality on components, things like a text box duplicate with no text and the focus in the text box, ready to start typing. I could see that getting confusing as one command has different outcomes…
