Easy CMS red circle with a white cross
Hello,
I’m using Easy CMS on my site hosted at Infomaniak. Everything was working fine until recently, but now when I click the **“Save”**button, I get a red circle with a white cross and the changes aren’t saved.
I’ve checked the PHP version on the server: it’s PHP 8.1.
A great Thanks for your help
hank you very much for your help!
I have similar problem. On my server the php Version is 8.3, and current Rapidweaver Version (9.4.3). I get the warning: Could not communicate with Total CMS. Either you have not published your project yet, or your website address is not properly set. But everything seems ok. Any hints?
Thank you for your help.
I’have got the solution from Joe Worman THANK’s:
"Delete the “depot” folder inside of cms-data on the server. That will fix everything.
Joe
The Big Chief"
