Is there a simple way to reset parameters in the Components? Layout, Filters Background, Background Overlay are complex little windows with many parameters (especially if you work with Hover Start End) and I sometimes I get lost and wish I could start over with setings. Is there a simple way to reset this panel (something like Alt + click or similar) ? Maybe add this to that little popup window with mouse right-click button which now shows only Single Group Mode?
Sorry if this was already discussed but on search I did not find the answer.
Ok, thats a good workaround, but if you have complex webpages you might do a mistake, dragging something accidentally or leaving stuff out while dragging it back.
Little pop up or key stroke combination with reset would be more elegant, maybe while working on the right side of the screen. Something within that specific control panel. My 5 cents.
I currently use UNDO’s by CMD + Z . . .but not ideal.
I close down all components either side, rename the folder old, create a new folder name new then select all, drop in, check the old folder nothing is left
I am not sure I understand or if we are on the same page. I am only talking about control panels on the right side of the app.
Lets say for example I work on Heading parameters in the Container . . I have many options with control panels = which are on the right side. I can work on Transitions, then I collapse this menu and maybe start working on Spacing . . then I do collapse that and start working on Effects.
Now, lets say I got stuck in Transition components panel and after many attempts back and forth I would like to RESET those Parameters to start over from default, but I do not want throw out everything I worked on in Effects or Spacing. Yes I can move to the left and throw out the full container or Heading but thats not what I am after. I was looking if there is a easy way to reset that specific control panel on the right side only.
Also. . . it would be great to have some visual feedback that there are changed parameters within specific components control panel when collapsed. Maybe have the icon of the parameter in blue if that control panel is active and has information as control panels do collapse automatically by default. Or is there a way to switch this off.
