Edit a remote resource
How do you edit a remote resource? I have Vimeo embedded vidoe that has a black backround that I want to get rid of, Vimeo says add ?transparent=0 to the link but I cannot see how to edit the resource link I added?
You can’t do that if you’re using the built-in resource manager.
What you’ll need to do is embed it manually via a custom component, that way you get full control over the output.
