Old Rapidweaver Classic user, but exploring the switch to Elements- I downloaded a trial and ENGINEER RW Classic Template to play around with.
Lots to learn, but one question I haven’t been able to answer is; how does one edit a Global container image? For example, in ENGINEER there is a Welding image in a Global container. When I click in the Inspector Background Image there is no image shown. I can unlink it and add one, but the original welding image is still there. No where can I find the Welding image. ?
In particular, I’m looking for the px size of that image.
Check in the node browser to see if everything on the page is in a container. Check the background section of inspector of that container and you should find the background of the page
So this is the Container that the background image appears in.
It does not show any Reveal component for the image, nor does the Inspector for the Container show an image in the Background. Still confused where and how the image is adjusted.
A couple more questions about the Engineer template:
How is the background color of the container holding the “welding” background image adjusted?
How are the text colors of the header texts “ENGINEER”, “PORTFOLIO”, AND “TEAM” adjusted? I can change the one within each individual page, but the others in that page do not.
Using the node browser, go through each component, and you will eventually find it. That also lets you see how each component is set up, and helps to wrap your head around the settings for the components.
So, I’m understanding Elements much better now, and am well underway to updating my website using the North Eleven Project as a starting point.
I’ve run into another stumper: In this Project Template page that I’ve duplicated, there is a grid with a container, and body text within it. The body text appears to have a right-hand margin, or a 700px max width that I have not found a control.
I dropped in another text box, and it stretches to the full width of the container.
What controls the body text width, and what is the difference between a text and a body text component?
