Editing Mobile & Sub Menus
Hi all, I must be missing something as I can’t see how to remove/edit the blue leaf icon or the purple button from my Mobile & sub menu (Sticky menu component). Can anyone point me in the right direction? … see image below.
Thanks in advance, R
Hi @Rich2020
you have to show this as a preview in your Editor. To do so please select as below
Then you can edit it.
Hope that helps!
You need to preview the Mobile Mobile & Sub Menu in the editor, here’s a video explaining how to do it :blush:
Thanks @Dan, that’s got me half way there.
I’ve deleted the icons but the browser preview isn’t matching the elements preview. Images attached.
I obviously don’t want the close ‘x’ to sit this low. I can’t see a setting that will fix this, can you help?
Thanks Markus,
I’d used the preview but was searching for a setting in the inspector panel. I’d not considered trying to edit the components directly. :roll_eyes:
Yeah, it is a bit hidden but at the end it is very logical.
If you remove the “mobile logo” your closing “x” moves upwards. If you want to prevent this I would put an empty container at the place of the logo and give the container a height of lets say 24 pixel. Then your closing “x” is moving down.
Thanks. :+1: Sound’s like a fix, though does seem a bit fudged.
