Hello again,
This new build introduces a detail view for store products, just click on a product card to open it. We still need to update all the products with more details and screenshots, but this is a good start!
There’s is a small issue in this build: The Install button in the “Purchases” tab appears disabled. As a workaround, you can visit the Store to Install your purchased products. We’ll have this fixed in the next update tomorrow. Sorry or the slight inconvenience.
What’s New in Elements 1.5.6?
- Added detail panel for store items
Purchase a License
You can visit the Elements website to purchase a license.
Elements Store is now live!
It’s a built-in place to discover, share, and buy products made for Elements: components, templates, projects, themes, and resource packs. You can browse free and paid products, install them directly into Elements, and even submit your own work to share with others.
Get the Update
Need a previous build?
If the latest build causes issues for your setup, you can roll back to an earlier version using the Release Notes page.
Give Feedback
