Element Blog
Yesterday/Today I wrote a blog and the status is “published” but for some reason when I try and test it locally it does not show up.
The previous written one seem to be fine, any idea what it could be?
This is the meta data:
title: “North Star in architecture: a guiding vision, not a finished blueprint”
date: 2026-08-13
author: Vivek
summary: “What ‘North Star’ means in software architecture: where the metaphor came from, how industry uses it, and how a review north star shows up at CycleRunCode Club.”
slug: north-star-in-architecture
status: published
tags: [code, coding, architecture, getting-started]
categories: [code, coding]
Any idea what is wrong? And I am on v3.0.9
Hi @vivek
Your front matter looks fine. It’s very difficult (impossible) to say without seeing the site and/or the project. Do you see other posts in the collection?
Thanks @ben for looking to help. Since I posted I noticed something interesting:
  1. All the previous blogs are visible and not issues with the site (so far)
  2. I published it locally around 1700 hours BST 12/08 and it did not show up
  3. I tried to change the filename/contents and still it did not show up (locally)
  4. Decided to wait for the next day to try, around 0013 hours BST 13/08 I tried and it blog still would not show up locally
  5. I changed the date to 12/08 on the blog and tested it worked, changed the date back to 13/08 its not showing up
  6. This morning 0835 hours BST and tried it locally, and I can see the blog
Not entirely sure what is happening here! It might have been something to do with the Solar Eclipse :smiley:
I will keep an eye out for this issue and if anything happens will revive this thread until then…
It sounds like “published” and the “date” are in conflict. I seem to recall that the CMS doesn’t usually show something if the date is in the future.
This brings up something I’ve wanted documented a bit better. A common thing I deal with is NDAs that have a do-not-publish-before date and time. So what’s the best way to do that @ben ?
Set the date and time to a date in the future and ensure the Collection component’s Filters->Date is set to “In the past”. Your Collection will then only show the item once the date and time has passed.
@thominator I have also written some custom styling for table display within MD as current its not supported. Not sure if you have covered it in your document.
E.g. LogViewer: what is coming next (and how it compares) check “How it compares (short version)” section
