Elements 0.6.2 (23294)
Hello again,
Just in time for the weekend, we have a rather nice build with further global improvements and a whole bunch of fixes. Enjoy!
What’s New in Elements 0.6.2 (23294)?
  • Globals can no longer be dropped inside themselves, causing a rip in the space-time continuum.
  • Documents now restore with the previously used device size
  • Fixed a crash that occurred during publish
  • Fixed a crash opening multiple documents on macOS 13
  • Fixed an issue where Accordian grouping was always being applied
  • Fixed an issue with muted and autoplaying videos
  • Transition classes are now applied when filtering
  • Fixed border opacity
Download Elements
You can always download the latest build of Elements using this link.
Purchase a License
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
my muted video still plays the sound
do you think its because I downloaded from you tube?
Can you please share your project with us (again) via Elements Cloud and we’ll see what’s up!
elementsapp://downloadDocument/U7wYHkFpCWQn
this is the link from you tube if that helps
Thanks @Godber, we’ve recreated the issue here and will get it fixed in a future beta. Stay tuned!
phew…just keep thinking its something I do wrong
I’ve found the underlying issue here and committed in a fix that will be included in the next beta.
The issue was that the muted control was mistakenly allowed to be “responsive” - so you could set the muted state individually across all devices, this shouldn’t have been allowed. The video is either muted, or not, across all devices.
When the next beta ships you will need to ensure the Muted setting on your video(s) are consistent across all devices, as I cannot reset the control value for all devices in this case.
Any new Videos you add will not have this issue, so if it’s easier for you, you could just remove the existing video(s) and add a new one!
cheers
