Elements 0.6.3 (23306)
Hello again,
This build is fresh out of the oven, and super tasty! We’ve continued to tighten up and improve Globals, along with adding some quality-of-life enhancements.
What’s New in Elements 0.6.3 (23306)?
  • Command-D now duplicates Components in the Editor.
  • PHP now works in Site and Page Templates!
  • Scrollbars are now accounted for when changing screen sizes.
  • Components can now be moved around inside of Globals.
  • Fixed crash during publish.
  • Added Tailwind Form Plugin (Form Components will be available in a later build).
  • Added border support in Divider Component.
Download Elements
You can always download the latest build of Elements using this link.
Purchase a License
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets, the sooner it’ll get implemented.
Hi @dan,
thanks for the new update.
  • Regarding the Divider, I can not find the border props,
  • Also the Scrollbar does not seem to be accounted for.
Not sure if I am doing something wrong.
Divider Screenshot
Other then that all good :smiley:
Is it intentional that components can only be duplicated with cmd+d in the editor, but not in the page layout panel?
@Beblebroks,
Oh no, some of the latest components that were updated weren’t compiled in :sob: The border controls will definitely be in the next beta (this week). Sorry for the delay!
Is there any difference in the behaviour of the scrollbars? Could you post a video showing the issue in the latest build…
We’ve just not coded it yet, it will be added sooooooooon…
Hi @dan
no problem. Just wanted to let you know.
Regarding the gap for with the scrollbar. They still are calculated with when setting to the specific breakpoint and when enlarging then it jump. Maybe also did not get compiled? Looks like the same behavior before.
P.S. … in the first part of the video I forgot to change the breakpoints (the window without the scrollbars)… tested that. It works. The second part with the scrollbar same problem like before. Shows in the video.
Thanks @Beblebroks, I’ve been able to reproduce it and working on a fix :+1:
There is one other thing that seemed to be fixed in the release which perhaps hasn’t been brought up. I started the tutorial using 0.6.2 and I noticed I couldn’t duplicate drag and item directly into the grid. I noticed that Dan didn’t either as his duplicated element fell right below the grid before he dragged it in. That is a pretty nice fix if it came out in this release!
