Elements 0.6.7 (23385)
@differentdan If you open the current Theme Project and then select the smallest mobile device screen to display it, a number of elements run off the side. This is a common issue I’ve run into a few times, and I’m sure others have, as well.
If you have time, it would be nice if you recorded a short video showing how you corrected those right-side run-offs. First, it would help me verify that I’m doing things right, but second, because it’s a common problem, it would be educational to have around.
In particular, the Text/Typography example is the more complex issue. My normal approach would be to try to take the side-by-side arrangement to top-bottom. But I’d be curious to see how you approached it.
No problems now. The build today fixed issue.
@dan
I think the updates to color in this build broke my existing colors. Am fully updated to 0.70
I had originally set the background color to a grey on the black palette. When I opened my site yesterday, all the backgrounds were black, as the black palette was all black and wasn’t grayscale.
Is there a quick way to fix, or do I have to touch each page??
You could overide Black in the Theme Studio and add back in the grey scale…
Worked!! Thank you!! Saved me a few hours
