Elements 0.6.7 (23385)
Hello again,
Today’s update is HUGE, and while that’s very exciting, it does mean a lot has changed, so there will be bugs. Watch out! :grimacing:
However, we’re on standby to fix and ship a new beta should any show-stoppers be found. Have fun, and remember to post in the feedback forum about any new issues you run into. :sweat_smile:
Watch Dev Diary Episode 70 and open this project once you’ve got the new build.
What’s New in Elements 0.6.7 (23385)?
  • Optimisations in Editor Performance
  • Improved Text Editing Performance
  • Added New Form Components
  • Added New Background Component, great for fixed image backgrounds and angled banners
  • Added New Image Slider Component
  • Added new “Blush” Theme
  • Updated and refined all existing Themes
  • Added “Article” Typography settings to all Themes
  • Typography component uses “article” by default
  • Fixed text editing issue where editor would turn grey
  • Fixed issues with Anchors not working in Text-based Components
  • Added support for ID’s/Anchors in Text-based Components
  • Added support for Magic FTP Links
  • Upgraded PHP to 8.4.4
  • Extended Tailwind Theme Colours: Brand, Accent, Surface, and Text
  • Added support for Tailwind 950 Colour
  • Video Component now supports Lightboxes
  • Theme settings now correctly handle the casing of “Default”
  • All components now use “Default” instead of “DEFAULT”
  • Dev settings are now cleared correctly on non-dev Themes
  • Component colour picker now uses correct custom colours
  • Typography settings for “Body” switched to “Paragraph”
  • Menu component now uses Gap setting for menu spacing on desktop
  • Theme Studio window title now shows the project and theme name
  • Theme Studio: Font Family, Size, and Shadow can now be rearranged via drag-and-drop (when building a custom theme)
  • Disabled quote substitution on multiline text areas
  • Reworked Gallery Component with new Lightbox
  • Fixed an issue where PHP wan’t handled correctly
Get Elements
Visit the elementsapp.io website to purchase a license today.
Update to the latest release
Give Feedback
I see you mention about the gallery…will I have to put a new gallery item and add photos again?
No, it should “just work” :blush:
cheers…brilliant job
just spotted a weird thing I need look into tho…my menus are a global and on some of the pages they are all bunched together…I will erase everything on my server first and upload it again
The Gap setting is now hooked up for the menu, you’ll just need to set that, so pick a number like 5 or above and you should be good to go!
have a look and see what you think on the photos page
I click on a photo and it total opens the wrong album
also if im in an album and click the back button it takes me to a totally different page hahaha ill reload all the albums later gotta eat
I tried redoing a test page with galleries and noticed whatever album you pick it goes to the last one(album/gallery
also the same when I redone a test page
UPDATE! Needed to add a container into the background component.
Bug found in Background Component. When I put text in the drop zone of the Background Component with a fixed image background the text is not visible when previewed in the browser.
The new build crashes in my navigation bar as I adjust text parameters. Also previous set up text appearances have changed with new build.
Can you share your project with us? (via Elements Cloud), and we’ll get it fixed tomorrow (Friday).
Done, Also, it would be nice to have an overlay setting for the image background setting for the Background Component.
@dan There are some great updates in this release. But I’m stuck with a crash every time I try to go and edit my custom colors in the theme studio. I sent in a crash report and I have tried it multiple times and it crashes every time I click on the colors item in the studio.
This has me dead in the water as I noticed that all of my accent colors are now messed up on my site.
I suspect the problem might stem from the fact that I have a custom color palette named “accent” and somehow this is causing a problem. I had attempted to preempt having to change all mof my accent colors from secondary to accent by creating this palette. Might not have been the best idea.
gave it a try but did not receive code. It looks like someone else in a later post has this problem too.
gallery app needs some work methinks
Don’t panic, we know what the issue is! We’ll get a fix out in the next build (hopefully tomorrow).
Replied on the other thread, and don’t worry, it’s under control. We’ll get it all fixed up and ship a new build tomorrow (Friday). Stay tuned!
Can you share your project with us (via Elements Cloud) so we can get this fixed?
Version 0.6.7 dissapear when asking for Check for updates saying 0.6.6 is the latest.
NVM .. just saw your post :smiley:
Try again, we just shipped 0.6.8 :wink:
