Elements 0.6.9 (23396)
Hello again,
Based on the feedback from Friday’s build, we’re back with a new and improved update to address some more of those pesky issues. We also managed to sneak in a requested Slider feature. Have fun!
Whats New in Elements 0.6.9 ?
  • Added support for autoplay in the image slider
  • Sorted the order of all theme properties
  • Fixed the typography issue
  • Addressed and improved numerous issues when using PHP
Purchase a License
Get the Update
Give Feedback
@dan This build does fix most of the problems with typography.
There is still a problem if you have a custom font size setup where it will NOT be applied either inline in the typography or Text component. I tried deleting my custom font size and replacing it, but that made no difference.
I sometimes use my custom font size for a lead paragraph inside a typography component. After this build that had appeared to be working, but turned out that it was not.
Getting closer.
Thanks, we’re looking into this one now and will get it fixed for the next release, very soon…
