Elements 0.7.1 (23429)
Hello again,
This week’s build addresses several new and long-standing issues, resulting in the best version of Elements yet. Please pay special attention to the Editor in this build, as we’ve made some significant changes to improve speed and stability — it’s possible that some new bugs have snuck in.
Keep the feedback coming and we’ll be back very soon with another new build!
What’s New in Elements 0.7.1?
  • Further optimisation work on the main editor
  • Changing themes will now update the browser preview
  • Changing a global now correctly marks other pages as changed
  • Added support for custom ID as the hover trigger on components
  • API: Dropzones in portals now show in the Node Browser
  • Minor update to various form component icons
  • Added support for right-clicking with the trackpad in the components view
  • Added support for line breaks when pasting text into text-based components
  • Added safeguards to prevent crashes when no homepage is set
  • Fixed an issue with inline text styles not displaying in the editor
  • We now generate a thumbnail from the first frame of an MP4
  • Fixed an issue where only the last checkbox value was being sent to email/webhook
  • Fixed an issue with dragging components over the scroll bar (especially important for RTL-based websites)
  • Added better support for highlighting components in RTL pages
  • Prevented reordering of font family, font size, shadow and typography list items when they are not in a dev pack
  • Non-required email field is no longer required for the form to send the email
Purchase a License
Get the Update
Give Feedback
Still not working. Last checkbox value is still the only thing that is sent by email. Yes, I have uploaded all files.
It should be fixed… can you try uploading your site again with the “Re-Publish All Files” menu option?
@dan I have done that. Not working.
In my testing everything was working, so I’ll need to double check this one.
Any chance I could get your latest project? :slight_smile:
I found the issue, and the fix will be included in the next beta :slight_smile:
