dan
(Dan)
9 April 2025 17:12
1
Hello again,
Hot on the heels of yesterday’s build, we have version 0.7.4 As well as a whole bunch of nice fixes, this build includes the new Modal Component
For more details on how the new Modal Component works, please watch Dev Diary Ep72 – New Modal Component .
You might also want to open the sample project and take a look at the example Modal page. Have fun!
What’s New in Elements 0.7.4?
Added Modal and Modal Close Components
The “Standard” navigation Component is now known as “Menu”
The "Sticky” property should now work in the editor
Page name changes are now pushed to the editor correctly
Folder names now use web-safe page titles by default
Added options to modify SVG output
Switching off Dark Mode no longer breaks the device’s UI
Link Pages now support any type of link (mailto:, tel:, php, etc.)
Added the “Elements” theme (work-in-progress)
API: Fixed an issue with using PHP in the portal head
Purchase a License
Get the Update
Alternatively, you can always download the latest build of Elements here .
Give Feedback
If you are running a licensed copy of Elements, please post all feedback in the Feedback Forum . You can use the Elements > Send Feedback… menu item to automatically pre-fill the build number into a new topic.
Bootsie
(Roger Radatz)
10 April 2025 08:58
2
Can’t get the update.
Either the download linke or the inbuilt update lead to an error.
Also the download speed is very slow.
Also I can’t post a jpg or png here.
dan
(Dan)
10 April 2025 09:09
3
Sounds like a network issue, as we host the files with Amazon.
Can you try a different network, or via your mobile network maybe?
Here’s the direct download for you to try again.
The fact you’re having issues with both downloading and uploading seems to point to a network issue to do with yoru location (or your Mac)
All seems to be working here on both download, and upload…
Pegasus
(Pegasus)
10 April 2025 09:25
4
@dan
do you have any idea why the download via the elements-app or rapidweaver-app regularly does not work?
i can rule out network problems, as other downloads are running in parallel and I only have this problem with downloads from you.
Bootsie
(Roger Radatz)
10 April 2025 09:26
5
Your direct download link worked. Speed only 320kb/s.
I haven’t changed anything.
I never had problems with downloads.
Bootsie
(Roger Radatz)
10 April 2025 09:27
6
Ditto.
Good to here I’m not the only one.
Pegasus
(Pegasus)
10 April 2025 09:28
7
@Bootsie
Which standard browser do you use?
Bootsie
(Roger Radatz)
10 April 2025 09:29
8
As I test my website projects while creating them I use Safari, Firefox, Brave, Opera, Chrome, Vivaldi.
Pegasus
(Pegasus)
10 April 2025 09:43
9
i actually meant which browser you use by default for downloads.
i suspect that there is some kind of conflict here if “Safari” is not specified as the default browser … because the downloads then work under safari.
Bootsie
(Roger Radatz)
10 April 2025 09:56
10
Aha.
My standard at the moment is Opera.
But I tried to download with Safari too.
I will now test with Safari as the standard browser.
Stand by …
Bootsie
(Roger Radatz)
10 April 2025 10:02
11
You’re right.
Download with Safari as standard browser took just a few seconds.
It should not be this way. You should be able to download with the browser of your choice.
Anyway … we’ve found the cause.
