Elements 0.9.10 (23663)
Hello again,
An awesome new build of Elements with a tonne of excellent fixes, Enjoy!
What’s New in Elements 0.9.10?
  • Accordion title area can now be styled with colour
  • The Delete key now removes a folder from Dev Packs correctly
  • Fixed an issue when duplicating templates between packs
  • Dragging of empty folders in template packs is now supported
  • Dragging resources from Finder into an image/SVG component now works
  • Fixed a crash that would sometimes occur when removing a component
  • Document is now marked as dirty when adding templates to the editor
  • Added support for deploy flags in dev components
Purchase a License
Get the Update
Give Feedback
