Elements 0.9.5 (23585)
Hello again,
We’ve added the first stage of Marketplace support inside Elements. You can now browse and download all free projects from the Marketplace directly within the Project Window. Just pick a project, and it’ll download and open in Elements, ready to explore or customize.
This is just the beginning. We’re working on deeper integration, including paid projects, component browsing, and more.
We’ve also migrated the recent work we did for publishing in Classic to Elements. While there’s still more work ahead, this marks a major step forward for publishing in Elements, bringing improved stability and laying the groundwork for the future.
What’s New in Elements 0.9.5?
  • New Marketplace Projects Window
  • Form component actually filters out turnstile response from emails
  • cURL: Jumped from 7.79.1 → 8.13.0: Brings faster transfers, improved HTTP/2 and FTP handling, and support for the latest protocols.
  • OpenSSL: Upgraded from 1.1.1 → 3.5.0: Building on TLS 1.3 with improved performance, stronger cryptographic controls, and long-term support.
  • libssh2: From 1.10.0 → 1.11.1: Enhances SFTP stability, key exchange robustness, and compatibility with modern servers.
Purchase a License
Get the Update
Give Feedback
Hmmm, @dan maybe only on my side, but no matter what project I am opening I got a bunch of errors like the below one.
The strangest update I ever had..all my projects went kaput!
”Syntax:error..everywhere..
Same!
Sorry about that, we’re looking into the issue now. Please stand by for an update!
Ok, a new build is available that fixes this issue so please give it another try!
Wow, publishing is a lot snappier now, good work!
@dan @ben Sorry to report that the Turnstile response is still showing up in the emails. I have tested it with two of my sites and both returned the response code. I did republish all files just to be sure.
Oh man, so sorry about this :person_facepalming:
We’ll look into it, and will make sure it is fixed next time we say it is :laughing:
Sorry @dan, It is working fine, I have now tested it on four of my sites and they all worked. I had been caught out by the bug where a Republish All Files DOES NOT catch the contact page. Once I forced the contact page to be updated everything worked fine.
All good!
Should that say marketplace? If so where do I go to find it? Doesn’t seem to be in the projects window.
See the video on this page: Elements Marketplace Integration 🔥
Good spot @KipV, I’ve fixed the typo.
Just click on the New Project button in the launch window to see it.
The problem is solved with this build. But I found another issue @dan @tpbradley. I cannot preview one of my projects in the browser. Pressing on the preview button does nothing.
Just tried other projects and they seem to work. What can prevent the preview to work?
I’ve seen this bug before, it’s because you don’t have a homepage set!
You’ll need to right-click on a page and set it as the Homepage, you should then be able to Preview that project.
Let me know how you get on.
Thanks @dan, that was it. As soon as I set a page as Homepage it was working again.
It is well-hidden, took me a few minutes to figure it out. It shows up when you go to create a New Project in the project window.
I wonder if at some point Elements will just go straight to that window when it opens up? Like the way it is in the Sketch app.
It certainly could do, feel free to let us know what your perfect welcome screen looks like!
The Sketch opening screen works pretty well. I momentarily got to test out the work spaces feature in their getting started screen when it was in beta and remember that working pretty well too. I use the discover section to stay on top of what is new and use the recent documents area as well.
