Elements 0.9.9 (23643)
Hello again,
Hot on the heels of yesterday’s release, we have a fresh new build!
You can now drag and drop pages into the templates area. Check it out:
What’s New in Elements 0.9.9?
  • You can now drag pages into templates
  • Fixed ordering of items when dragging from editor to templates
Purchase a License
Get the Update
Give Feedback
@dan not updating at my end
same here
download is 9.8
Looks like there was a caching issue, try again now guys!
@tpbradley
good now
dragging a page in is brilliant :rofl:
Good work peeps! :smiley:
Possible bugs (or I’m missing something :thinking:):
  • Buttons not aligning
  • Missing option to add theme at Theme Studio
Oh found how to correctly align the button :face_with_tongue:
haha yeah, use the Margin control (like in CSS). Here’s a link to the manual that explains it along with a video.
I have just loaded the update and I am now getting this after install and relaunch?
@dan how does the button size setting for the trigger-modal work?
i have set a button to a size of 80%. but as soon as i move this button to the trigger-modal, the size is lost.
in the modal trigger itself i have no possibility to set anything.
here a short video
here the link to the project
global or transform does not work in the modal trigger either
trying that crashed Elements, report was sent
Elements stores your publishing password in the system Keychain. Enter your system password and hit the “Always Allow” button.
That will solve it for you.
This looks like a small class issue in the modal component, @ben is going to take a look and get a fix shipped in the next build :crossed_fingers:
Thanks but using beta for over 6 months loads of updates but first time I’ve ever had this. See Dan has also commented below so I’ll wait. Thanks for taking time to reply!
Hey @PMUK,
Nothing to worry about, this is expected behaviour. Occasionally, we update the AWS libraries that handle authentication, and macOS will detect that change and prompt you to grant access to your keychain again.
Just enter your login keychain password, click Always Allow, and you shouldn’t see the message again. That is until we update the libraries again.
