Elements 1.0.1 (23692)
Hello again,
This build fixes and improves the publishing engine. There’s more to come on the publishing front, but we wanted to get this out and keep the updates flowing. Enjoy!
What’s New in Elements 1.0.1?
  • Fixed an issue with new lines being added at the start of the site template
  • Added graceful handling of running FTP connections during cancellation
  • Improved handling of AWS errors
  • Improved connection stability
  • Create fresh connections on failure
  • Expand retry logic to catch more errors
  • fixes a crash if the server is offline
  • Neumerous other under-the-hood publishing improvements
Purchase a License
Get the Update
Give Feedback
I tried to download it from the website, but got some errors and it failed to proceed. I see you just posted this within minutes, so I wonder if your own site is still currently updating. I’ll check back in a few, but I thought I’d drop this note just in case something was going wonky that you weren’t aware of yet.
Thanks for all the hard work! Rapidweaver fan here :slight_smile:
If you already have the app installed, you can just check for updates whilst it’s running.
I’ve tested the download and it’s working fine here; maybe give it another go!
The first time I tried to publish with this new version, it crashed after a few hundred files. Second time, it seems to be going fine, but I have noticed that the progress bars for each connection are not updating; they do not animate. Not sure if this is because the upload is so fast that it does not register. Plus, after the crash, only four connections could be opened instead of the specified six.
same here regarding the progress bars
Thanks guys, I have the crash report so I’ll get that fixed up and I’ll see what I can do about the progress bars too. :+1:
All is working fine now, it was probably me :slight_smile: Elements has been purchased and downloaded! I’m looking forward to digging into this, it’s an excellent opportunity to remake my website.
