Elements 1.0.5
Hello, When I purchased Elements, a few months back, it was version 0.9.7 (beta). now that Elements 1.0.5 is available. How do current element users get the update version? Thank you.
@Zuo4she3
open Elements, click on Elements menu item, then click check for updates
In Elements menu item, click settings, then updates, check auto check for updates
@Zuo4she3 Yes, make sure Elements is in your Applications folder, it should prompt you and update automatically.
You can always download the latest version from the Elements website. Here’s a direct download link.
