Hello again,
This new build fixes some early issues with the CMS when publishing to a live server. We’ve also changed the way links are created and handled when dealing with authors. Take a look at the updated sample project below to see the changes.
Open Simple Blog Project in Elements.
What’s New in Elements 1.1.1?
- Fixes issue where a lowercased cms.php file was attempting to be included, causing a PHP fatal error
- Adds ability to fetch single Item’s via customisable URL query parameters (you can now fetch an Item via the item=, author=, or tag= params)
- Tag and Author filters are no longer case sensitive
- Related Tags and Authors now set unique query params. Uses tag={tagSlug} and author=authorSlug instead of generic item={postSlug|authorSlug|TagSlug} (allows you to fetch single tags or authors via the Item component)
Purchase a License
Get the Update
Give Feedback
