Perhaps you toggled the “mask” icon, that will tell the control something has changed, and make it bold. If you “Reset to Default” that should reset everything correctly.
We could probably tweak things so this doesn’t happen, but it’s probably not a big deal…
I would have thought that the Spacing heading should still be in blue if any of the controls are overridden (in bold) and it isn’t. That seems like a bug. If the group was collapsed you would have no indication that a control was altered.
As a suggestion, it might be nice to have a function: Collapse all non-modified groups / Expand all modified groups (if all groups collapsed). That would really allow you to focus on what had changed.
Great job. However, I’d like to express some concern regarding the new ‘visual highlighting for inspector groups.’ While it is a good idea in some respects, turning the text blue whenever a single property is modified feels a bit overkill. Since properties are tweaked very frequently across various groups, there is a real risk that we’ll end up with all the group names in blue (which doesn’t look great, visually speaking). Because ultimately, if they end up being practically all blue, they won’t stand out anymore, and that defeats the whole purpose.
I saved and reopened the file, the highlighting was not there before saving save and open remembered the change even though set to default and before saving was not showing the change
@tpbradley Tom thanks, further testing suggests interaction rather than changing a default and it’s not across the board, able to switch off and on like outlines would be brilliant, I don’t need to know what I changed (already know), once there all blue? What do I need to change to fix an issue, just my thought.
Turning on outlines is the main thing I use, additional info from that would help even more to understand a layout issue. Think the outlines option is probably the most powerful feature, seeing the layout symmetrical etc. smaller screens becomes a bit more difficult, I’m rambling
Not the end of the world having every setting change blue
