Elements 1.6.3 (23992)
Hello again,
We’re back with a quick update to Elements that adds some much-needed improvements and polish.
Alongside fixing issues with favicon generation, we’ve also added a new step-by-step guide to the manual, plus a short video tutorial to walk you through the process. Together, these should make getting your site icons set up faster and easier. Enjoy!
Oh, and you can now also edit empty text components :laughing:
Lots more good stuff to come. Stay tuned, and welcome to 2026 :tada:
What’s New in Elements 1.6.3?
  • Added Favicon generation
  • Added right-click Edit Text menu item
  • Improve Project Settings UI
Purchase a License
You can visit the Elements website to purchase a license.
Elements Store is now live!
It’s a built-in place to discover, share, and buy products made for Elements: components, templates, projects, themes, and resource packs. You can browse free and paid products, install them directly into Elements, and even submit your own work to share with others.
Get the Update
Need a previous build?
If the latest build causes issues for your setup, you can roll back to an earlier version using the Release Notes page.
Give Feedback
When you add a right-click something, is it possible to add a control-click too? @ben
:clap:
Wish fulfilled :folded_hands:, nice gift for designers in 2026. This feature opens the door to complex text design that was previously almost impossible to manage.
You should be able to use Ctrl+click now. It should bring up the same menu as a right-click. Are there any places in Elements where this isn’t working for you?
On the blue text seems to work now: control+click @tpbradley
Ah yes, I’ll try and fix that up!
