Elements Base or Elements Plus
Hi everyone,
Having had my site stop being functional in RW8 + Foundry (luckily it’s now working after upgrading to Stacks 5), I can see as a longer term plan I need to upgrade and rebuild my site in Elements and want to take advantage of the current discount.
I’m unsure whether to go for Elements Base or Elements Pro - I can see the difference is around the amount of custom and global complements (limited vs. unlimited) and was wondering how and how often you use these within your builds to help me make my decision.
I am no expert in this so went for the Plus licence in my first year because I am building two new sites and didn’t want to be limited by the licence restrictions.
Regards
Roger
Hey @ham-uk,
I think you’re going to love Elements once you move to it!
With regards to the license, we recommend most users go for the Plus license. You can upgrade or downgrade in app at any time. You only need to go for a Pro license if you’re building paid client websites.
Everything is explained in more detail on the license page in the docs.
Hope that helps, but do let me know if you have any more questions.
Cheers!
I went with plus, then upgraded to do a client site…
You’ll find lots of help here!!!
-Mike :slight_smile:
