Sometimes beta builds are like busses, you wait for ages, then suddenly several coming along at once!
What’s New in Beta 15?
- Fixed an issue with Custom Components not appear in Preview
- Fixed an issue with the Component Inspector appearing empty
Update to the latest Beta
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received when purchasing a license — the link in that email will ALWAYS give you the latest version.
Give Feedback on the Beta
If you are using the beta, please post all feedback in the Elements Beta Feedback Forum . You can use the Elements > Send Feedback… menu item to automatically pre-fill the build number into a new topic.
Get the Beta
If you’ve already signed-up for the beta, it might be a while before you get an email as we’re working our way through all the feedback. Hang tight for a little longer, you will get access in the coming weeks and months. If you’re not on the list, you should sign-up up here to be notified when the beta is publicly available.
