Hello again,
We’ve been hard at work on lots of improvements to the core of Elements. Unfortunately, this build doesn’t contain the V2 Components or the new text editing controls, we’re still working on those ![]()
What’s New in Beta 16?
- Deleting components no longer produces duplicates
- Converting a component to a Global no longer causes a crash
- Dragging and dropping components between documents now works (again)
- Documents no longer marked as dirty upon open
- Code editor now keeps it’s position during each session
- Main Editor now remembers scroll position per page
Update to the latest Beta
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback on the Beta
If you are using the beta, please post all feedback in the Elements Beta Feedback Forum . You can use the Elements > Send Feedback… menu item to automatically pre-fill the build number into a new topic.
Get the Beta
If you’ve already signed-up for the beta, it might be a while before you get an email as we’re working our way through all the feedback. Hang tight for a little longer, you will get access in the coming weeks and months. If you’re not on the list, you should sign-up up here to be notified when the beta is publicly available.
